Horizontal scroll on landing page
    I’m having a problem with my landing page on mobile. I first noticed there was a horizontal scroll on the page. Tried to adjust this by setting a max width on all the containers but then I see a white vertical border on some mobile devices obviously. What’s the best way to fix this?
    Thanks in advance!
    I don’t see the issue in the browser inspector, but I think the overflow is caused by the section under the page hero — the one with the green checklists section and an image.
    Can you try temporarily removing that section and check if the overflow issue is still there?
    If it is, try rebuilding the section using a GB Grid block — the current one uses the core WP Column block, which sometimes has responsive issues.
  • Yes indeed, the problem seems to be caused by that block. Do you have any suggestions on how to rebuild it with GB so that it looks like the one being used right now?
  • You can use GB’s grid block instead of WP’s columns block.
