kernfunke
Problem Description:
I have created a button using Global Styles in GenerateBlocks, which is designed to have a hover effect: the button is normally white, and upon hovering, the text turns white and the background fills with color, similar to a progress bar effect. This effect works correctly in all browsers except Firefox.Expected Behavior:
Upon returning to the page, the button should retain the defined hover properties, and the text should revert to its original color.Actual Behavior:
Both the button and the text remain white, leading to readability issues (the hover effect persists).I would appreciate it if you could look into this issue. Should you need any further information, please let me know.
I can’t seem to replicate the issue from my end from Firefox.
I may be doing something wrong.
Can you share a screenshot of the issue from your end?
kernfunke
Hi Fernando,
thank you for your fast reply!
I can sure share a screenshot.
Best regards
Yannik -
Here’s an article regarding Uploading Screenshots: https://docs.generatepress.com/article/using-the-premium-support-forum/#uploading-screenshots
Once you’ve uploaded it, share the link to the uploaded screenshot here(in the Private Information field if you want).
kernfunke
src=”https://postimg.cc/gallery/YHYqXLq” alt=”before and after clicking” />
I see. Can you reshare the link to the page in question? I’ll recheck the issue.
kernfunke
https://interco.gmbh/en/
> section “Our products” > Dynamic seating > Learn more
(The other links are not activated yet) -
Hi there.
could you try adding this CSS to your site:
a.gb-button:hover { position: relative; }
It may seem random but it was a previous method to fix this FF bug.
