hover effect
  • hello,
    is there any way to create (with generateblocks) an image with an text over it and to change this text on hover. Perfectly appears a layer with new, something like here https://hotel-xenia.plethorathemes.com
    Angel
  • Hi Angel,
    Do you mean this section?
    https://www.screencast.com/t/bWCrHVZ4
    If so, it will require some custom CSS.
    1. You can build the structure shown below:
    https://www.screencast.com/t/PXrr8Ara
    Settings for container a:
    – width: 33.3%
    – height: 100%
    – min-height: 500px (you can adjust the value)
    – display: flex
    – flex-direction: column
    – overflow-y: hidden
    Settings for container b:
    – min-height: 100%
    – z-index: 2
    – position: relative
    Settings for container c:
    – display: flex
    – justify-content: flex-end
    – min-height: 100%
    2. Add the container link to container b by clicking the link icon in the floating toolbar.
    https://docs.generateblocks.com/article/container-links/
    3. Add an additional CSS class to container c, eg. overlay, add an additional CSS class to container b, eg.base.
    https://wordpress.org/support/theme/generatepress/
    4. Add this CSS:
    .gb-container.base:hover + .gb-container.overlay {
        transform: translatey(-100%);
    5. Add transition for container c at Effect > transition.
    https://www.screencast.com/t/MHs9wlW0lO
    Let me know if this helps!
  • you are really a machine!! it works
    when I cross over the image, the layer with the text appears. but i have to let the mouse without moving, otherwise the layer “moves” (appears and disappears) and it is a little bit annoying. is there a way to avoid this?
    Thanks again
    try adding this CSS:
        pointer-events: none;
  • good afternoon,
    Everything works perfectly but I can’t get to put a link on the hover. Could you please have a look….?
    thanks in advance
  • Sorry, I haven’t told you correctly the problem. I can put the link in the hover into the blocks rooms, environment and paragliding but when I pass over the hover with the mouse and clik on it, the link doesn’t work and a new window doesn’t open.
  • The login doesn’t work, I can not see your site.
    Can you check?
  • Make a flushdns. The website was under a different ip since yesterday more or less….
  • OK, lets go back a couple of steps:
    1. Container B, remove the base class
    2. Container A, add the base class
    3. Change this CSS:
    to:
    .gb-container.base:hover .gb-container.overlay {
    4. remove this CSS:
  • Thanks a lot. It works 😉
  • Glad to hear that
