I have a Pro version. Can you guide me through making image hover effects like those in the link? Thank you.
You’ll need to experiment with the Effects module to achieve that effect.
https://docs.generateblocks.com/article/effects-overview/Unfortunately, we can’t provide the exact settings for the Effects module, but I can offer some CSS to achieve that, assuming you already have a layout similar to the example and just need to add the effect.
Hi Alvind,
Can you share me the CSS code and I’ll try them out tomorrow.
Appreciate it.
Can you link me to the page and section where you want this effect to be applied? I need to see the selector to provide the correct CSS.
Sure, I just add some comments in private information.
as those images are not 100% width of the container and you want to maintain the border radius ( I assume ) then it will require some CSS:
.has-zoom-image figure { width: max-content; margin-inline: auto; overflow: hidden; border-radius: 20px; } .has-zoom-image figure img { transition: transform 0.2s ease; } .has-zoom-image figure:hover img { transform: scale(1.1); }
Then select the Container Block that has the image inside and give it a CSS Class of:
has-zoom-image
Note the CSS adds border-radius and auto margins ( to center ) to the
figure
element which wraps the image. This is so the image can be zoomed into and not scaled bigger. -
Hi David,
Thank you so much. The code works.
If I add a container outside the image, can I get the same hover effect with the image block instead of additional CSS?
So if you add the Container Block around the image, and set the Container Blocks:
i) Layout > Overflow X & Y to hidden
ii) Sizing > Width tomax-content
iii) Spacing > Margin Left & Right toauto
iv) Border Radius , set the border radius here instead of the image blockThen select the Image Block, and create a Transform effect
Set the:
Type to Scale, Device to Desktop, State to Hover and Target to Self.
Then adjust the scale for the effect.
Then Click to add the Transition -
Issue solved, thank you!
Glad to hear that !
