how can I make the image look like this? – https://imghostr.com/15545a_57t
If you want to add rounded corners and more space above and below the image, the use a GenerateBlocks Image block.
In the Spacing options of the image block you can add Top and Bottom Margin as well as set the Border Radius
I know that.
but look at the image I have on my page.how can I achieve the image I provided in the screenshot?
What’s wrong with the image? Too small?
If so, it’s because the height is set to 250px, so the width is 166.66px to respect its aspect ratio, unless you also set a width value for it.
how can I make the image look like this? https://imghostr.com/15545a_57t
1. Select the container block which contains the image block, set
displaytodefaultinstead offlex.2. Select the image block, set
widthto100%,heightto300px.Let me know if this helps!
Done.
it still looks stretchy.
any idea how to fix it?
You need to set the Object-fit of the Image block to
cover.You can then move the image position through a CSS like this:
img.gb-image-77f936f3 { object-position: center 70%; }
