gunrose2003
I want to implement an FAQ dropdown effect on my page; how can I achieve this using GP or GB pro?
Thank you. -
Do you have an example of the effect you’re looking for?
gunrose2003
like your official site: https://generatepress.com/blocks/
We simply use the Accordion block’s default transition setting, which you can find under the Settings tab: https://cln.sh/Z4wm41CY
gunrose2003
Do you have detailed tutorial?
I don’t think a detailed tutorial is necessary. When you add the Accordion block, the option is already available—you can simply choose between Slide, Fade, or None for the transition effect. No additional settings are required.
