gunrose2003
I want to incorporate the “Submit a ticket” function from my FLUENT SUPPORT into this right-side sliding window on my website. How can I achieve this using GP or GB PRO?
please check screenshot:
My requirements are:
1. It should work on both desktop and mobile devices.
2. The right-side slide menu should feature a SUPPORT icon (SVG); when the user clicks it, a “Submit a ticket” window slides out for immediate input, similar to AJAX functionality.Thank you.
Unfortunately, this feature requires a custom solution, which falls outside the scope of our support.
gunrose2003
i remembered that you have right slide bar solution. which part can not be achieved?
I don’t recall that feature being available. Perhaps you’re referring to the Off Canvas Panel?
gunrose2003
yes, Off Canvas, can i put it into right slide bar?
The Off-Canvas panel can be triggered using the
data-gpmodal-trigger
attribute, which you can add to the “Support” button. However, creating and positioning the button exactly where you want it will require a custom solution.
