Hi
I have built a button without effects (nor Transition, nor Transform). Although I have not built any effects, effects are visible. However, I have not turned on any of the wrenches and yet the button moves as if an effect were programmed. Neither globally nor locally do I have templates associated with the button. There are also no html anchors associated (at least I can’t see any) with the button. The button type is “link”.
What can I do? I have imported a page template and suspect that the button template is associated with it but I don’t know how to turn it off.
Thanks for your support, but I have searched the documentation for any clues and also searched the forum for them.
Erwin
can you share a link to your site where i can see the button with the effect ?
OK, go to Customizer > Additional CSS and DELETE this CSS:
.button, .gb-button { -webkit-transition: all 500ms ease-in-out !important; transition: all 500ms ease-in-out !important; } .button:hover, .gb-button:hover { -webkit-transform: translate3d(0, -4px, 0); transform: translate3d(0, -4px, 0); }
Thank you David
solved!Regards
Erwin -
You’re welcome
David,
So far so good, but I still can’t affect the color of a “global style” element of the font. I have defined a “global style”, but I can’t influence the font color, no matter how I change the color. There is still a factor that influences this part.
Can you recommend something?
Also, the button does not look identical in the backend as it does in the frontend.
Regards,
Erwin -
Hi David
Probably I could solve the problem: I had to set a link within a button in the “Global Style” (#) only then the individual buttons were displayed in the correct parameters if they were linked to a page.
Regards and thank you
Erwin -
Thats correct, otherwise theirs not
a
selector in the CSS.Glad to hear you found the solution
