In the Private Info field below you can share the URL and Login details.
Yolanda Lippens
See info below, thanks!
Hi Yolandal,
1. Set “Excerpts in light blue – Page Hero” to draft.
2. Open “Titel blue”.
3. Duplicate and edit this Container as instructed by David: https://share.getcloudapp.com/xQuE9YGj
Yolanda Lippens
Hello David and Fernando,
Well, finally I understand why I was stuck because I had 2 different Elements!
Now that I’ve duplicated the block in the same Element, it works!
So, I’m very happy, thanks for the great support – as always!Yolanda, NL
You’re welcome, Yolanda!
Yolanda Lippens
Hello David,
I’m afraid I have to re-open this topic.
I’m having issues with the excerpts, as they now also show below the light blue bar.
See this screenshot.I didn’t change anything, but I must say I had an PHP script in my snippets that was corrupt, which made this Element also corrupt. That is fixed now, but it seems that this Element isn’t working correctly anymore.
Can you see what is going on?
URL is https://pijnmc.nl/medicatie/duloxetine/Thank you,
Yolanda -
Hi Yolanda,
So we can take a closer look, can you also share admin login credentials through the Private Information field?
Yolanda Lippens
Yes I will, thank you!
Thank you! I’m not seeing anything blatant that should be adding this. To test, can you try #1 here to debug: https://docs.generatepress.com/article/debugging-tips/
It’s recommended to backup your site before proceeding with this.
Let us know how it goes.
Yolanda Lippens
Hi Leo,
Oh, that is a bit disappointing, I was hoping you could find the issue to solve it.
I will send you a message in the private box. -
The excerpt above the content is INISDE the actual content.
For it to appear then would mean something is filteringthe_content()
First what happens if you disable the
Titel blue
element in Appearance > Elements by Quick Edit and set the Status to Draft ? -
Yolanda Lippens
Hello David,
A good idea to disable the Element.
When I disable it, the Excerpt still shows, see this screenshot.And when I publish it again, it looks like this (I’ve changed the manual excerpt to get it more clear)
https://i.postimg.cc/G2xW9F31/20230628-001115.jpg -
OK, so the Element is not causing any issues.
And if you completely disable the Litespeed caches ? Does it still show. -
Yolanda Lippens
If I disable the Element, and flush the cache, there is still an Excerpt shown, and I don’t know where this is coming from 🙁
(Although I know the text is typed in the r/sidebar in the ‘Exceprt’ block) -
Try temporarily disabling AlL other plugins aside from GP and GP Premium.
Does it still show ? -
Yolanda Lippens
Yes, I have found it!!
It’s a long story to tell you what caused it, but I’m very grateful you pointed me to this path!!
Thank you David!!! #my_hero
