How do I centre post author
  • Hi there
    How do I centre post author? I tried this, but it doesn’t appear to work:
    .post-author {
        text-align: center;
    And I want it unlinked. Currently links to my author profile.
    TIA.
    Could you share the page where I can view the post author text?
  • You can use this CSS:
    .single-post .entry-meta {
      text-align: center;
    To remove the author link, you’d need to add this snippet:
    add_filter( 'generate_post_author_output','tu_no_author_link' );
    function tu_no_author_link() {
    	printf( ' <span class="byline">%1$s</span>',
    		sprintf( '<span class="author vcard" itemtype="http://schema.org/Person" itemscope="itemscope" itemprop="author">%1$s <span class="fn n author-name" itemprop="name">%4$s</span></span>',
    			__( 'by','generatepress'),
    			esc_url( get_author_posts_url( get_the_author_meta( 'ID' ) ) ),
    			esc_attr( sprintf( __( 'View all posts by %s', 'generatepress' ), get_the_author() ) ),
    			esc_html( get_the_author() )
  • Thanks.
    One final thing:
    1. How do I increase the font size of the author?
    2. How do I decrease the space/gap between the post title and the author?
    TIA
  • You can replace the previous CSS with this one:
      text-align: center;
      font-size: 18px;
    h1.entry-title {
      margin-bottom: 10px;
    Feel free to adjust the values to your preference.
  • 🙏 And one final question (yeah right)
    How do I change the font color and weight of author?
    TIA
  • Just add these properties to the previous CSS:
     font-weight: 900;
     color: red;
    So the final CSS will be:
      text-align: center;
      font-size: 18px;
      font-weight: 900;
      color: red;
  • And one final thing (I hope). I cannot see the author link on my blog posts here, https://www.eatweeds.co.uk/page/2
    TIA
  • Hi Robin
    do you have any PHP Snippets that alter the display of post meta ?
  • What does the “Remove Author Link” snippet do ? 🙂
  • It is the code Alvind gave me earlier today to remove linked author name so only the name shows (no link). Here’s the code:
  • Ah ok… sorry I should have seen that.
    If you go to Customiser > Layout > Blog –> Single tab:
    https://docs.generatepress.com/article/blog-content-layout/#single
    Is the Display Author checked there ?
  • Your screenshot shows the option under the Single tab, can you check the Archive tab?
Viewing 16 posts - 1 through 16 (of 22 total)
