How do I customize Category page?
  • Hello guys
    Category page How do I customize it to make it similar to: https://www.semrush.com/blog/
    1- I want to remove the margins
    2- I want to change the box size of the article
    3- I want to change the category icon
    You can create your own layout by using a block element – content template:
    Here’s the doc:https://docs.generatepress.com/article/block-element-content-template/
    Please watch the video to understand the concept.
    Let me know if you need further assistance on this 🙂
  • I’ve built a site in the past, and attached a link for you to see how the articles appear on the categories page, knowing there’s no Element for that thing?
  • Well, using an element is actually the easiest solution among all the approaches, and it is very powerful, if you’ve never used one, I would strongly recommend learning and trying it as this is the core value of GP Premium and GB as well.
    But if you don’t want to learn, it’s ok too.
    There’s no margin applied, I assume you are talking about paddings, here’s the CSS to remove the paddings:
    .generate-columns-container .post .inside-article {
        padding: 0;
    Do you mean want to have more columns?
    If so, you can change the column number at customizer > layout > blog.
    you can use the generate_svg_icon filter.
    add_filter( 'generate_svg_icon', function( $output, $icon ) {
        if ( 'categories' === $icon ) {
            $svg = 'your_svg_HTML_goes_here';
            return sprintf(
                '<span class="gp-icon %1$s">
                    %2$s
                </span>',
                $icon,
                $svg
        return $output;
    }, 15, 2 );
    Just replace your_svg_HTML_goes_here with your own SVG icon code.
  • Thank you, Ying, for the advice
    I will learn this point and start using it
  • You are welcome   🙂
    Hope you’ll enjoy learning and using GP elements!
