How do I get an infinite scroll function on blog posts?
  • Hi Support team,
    This does not work for me. I have checked ‘use infinite scroll’ but when you get to the bottom of my blog posts, nothing happens. I want my blog posts to load the next post when the reader reaches the bottom.
    I deleted all plugins to use infinite scroll. But Infinite scroll doesn’t work though. Pleas help me
  • Hi Teo,
    You’re using a Block Element – Loop Template in Appearance > Elements.
    The Infinite Loop feature doesn’t work for that.
    Set the Loop Template to draft and create a Block Element – Content Template instead. Reference: https://docs.generatepress.com/article/block-element-content-template/
  • I’ve solved this! thank you.
  • You’re welcome, Teo!
  • Yolanda Lippens
    I would like to jump in on this topic. I’m curious how Theo got the infinity loop working?
    @Fernando, in the link you mention, I don’t see the option to set the infinity loop (instead of pagination).
    What am I doing wrong?
    And second, I’m also wondering when this funtionality will be implemented as said by Brian a year ago?
    https://generatepress.com/forums/topic/infinite-scroll-query-loops/
    Thank you!
    Yolanda, NL
    Infinite scroll is an option in the Customizer > Layout > Blog.
    And what Fernando said is it will work with the Themes blog template and a Block Element Content Template.
    Infinite scroll will be a future feature of GenerateBlocks Pro, we have no timeline set as yet
  • Yolanda Lippens
    Thank you David,
    I don’t use the Layout > Blog as I have many pages with categories that I set up as a blog. I used WP Show Posts, but I’m now rebuilding every page with the Query Loop and set all categories separately.
    I’m looking forward to the update with the Infinite Scroll.
    Thank you!
    Yolanda
  • NOTE that the future infinite scroll feature will require GenerateBlocks Pro
    Glad to be of help
  • Yolanda Lippens
    Thank you David, I’ve already purchased it!
