I have enabled the “Allow people to submit comments on new posts” in the Settings/Discussion section but I still don’t see a comment box in my blog posts.
How can I enable it?
Thank you.
That setting only applies to new posts. For existing posts you need to check each post’s settings:
- Edit a post → in the right sidebar open Discussion → tick Allow comments.
- If you don’t see it, click Options (3 dots) → Preferences → Panels and enable Discussion.
Let me know if you need further assistance, I’m here to help.
Hi Chaz,
Thank you for your response. Unfortunately, I cannot find Panels in the Options (3 dots) → Preferences option.
In the right sidebar, click the 3 dots → go to Preferences → under the General tab, enable the Discussion toggle button.
After that, the Discussion panel will appear in the post sidebar where you can allow comments.
For more detailed guidance you can view this screen recording: https://share.zight.com/z8ug16W7
The discussion toggle is enabled, but I cannot see the comments section.
Can you please tell me if I am doing something wrong?
I have provided Admin access for your convenience.
In your Posts list, select all posts, then go to Bulk actions > Edit, and set the Comments option to Allow.
You can follow this short screen recording for reference:
https://cln.sh/x35fN4Pd2PzYCPNSPtdt
