How to add color to seperate text word
  • hi
    how are you
    pls check https://prnt.sc/PTCmoRbmofdD
    How to add color #015cb5 to the seperate word “CREATE” , and other words keep the white color
    Pls check the temporary admin access in the private message
    pls help to fix that
    I would suggest you redesign your heading in the following way:
    Right now, you have a container that includes two paragraphs but from what I see from the card layout that you have is the following: A heading followed by the embed YouTube video. It would be better to remove the two paragraphs and replace them with an H2 headline block. Write the full sentence MOSRAC EXISTS TO HELP PRODUCT INNOVATORS CREATE. Then, For the outer container, set max-width to 340px. Select the word, CREATE and click the down arrow from the toolbar.
    Block editor toolbar
    Select Highlight, then pick a color from the global colors already set up. If you want to pick a custom color, click the area above where it says No color selected and and paste your color value in the box below the Hex label.
    Custom Highlight color
    Here they are not Heading 2 text, they are just normal text
  • Ok, then just follow my last advice.
    For the MOSRAC EXISTS text, set the color to white.
  • HI
    YES, I DID THAT WITH YOUR HELP
    now the color is OK
    https://prnt.sc/Ldlcr_fQVoN_
    but i want to
    1. TO help product is one line
    2. MOSRAC EXISTS is online
    3. innovators create is one line
    i adjust the font size, line weight, can not do that,
    pls help me to fix that
    thanks
  • Ok, please remove the max-width value that I showed you earlier. Put the mouse cursor just before the TO HELP text and click SHIFT + ENTER. This will force the headline to a new line. Similarly, put the cursor just before the INNOVATORS CREATE text and hit SHIFT + ENTER again.
  • HI George,
    Cheers
    Thanks for help and patience.
    If possible, would you like to answer another topic?
  • Hi again.
    You can create other topics if you want and either me or one of our support staff will answer!
