YEAR93
I want to add a custom font that I’ve developed to my theme. I’ve read this article https://docs.generatepress.com/article/adding-local-fonts/, but it seems to be specifically for local Google Fonts.
Could you please guide me on how to add my custom font so that I can select it from the customizer panel -> typography?
That article should still apply. The only difference is you would need to create your own @font-face rules.
Here is an article that may assist you: https://css-tricks.com/snippets/css/using-font-face-in-css/#aa-deepest-possible-browser-supportAlso see: https://developer.mozilla.org/en-US/docs/Web/CSS/@font-face
Example, if you set the @font-face rule as such:
@font-face { font-family: "trickster-test"; src: local("Trickster"), url("trickster-COLRv1.otf") format("opentype") tech(color-COLRv1), url("trickster-outline.otf") format("opentype"), url("trickster-outline.woff") format("woff"); }
Then, you need to type
trickster-test
as the font manually in the Typography module.You can also add it to the dropdowns with these two filters:
Generateblocks font filter: https://generate.support/topic/custom-font-dropdown-gb/#post-30043:~:text=Yes%2C%20you%20can%20do%20this%3A
GP font filter: https://generate.support/topic/removing-fonts-from-font-family-dropdown/#post-22123
