Cheezballz
I’m working with the Wellbeing template and I cannot figure out how to get the page hero to show the featured image instead of a static background image. I used to know, but the settings have changed.
For the ‘Page Hero – Pages’ element, I tried putting
{{featured_image key:url}}into the Inline Background Image field for the main Section container but it’s not working like it does for the Section container in the ‘Template – Single Post’ element. Why is this?I did add a featured image to the About page, and it’s displaying below the header.
It should work.
Can you provide an admin login and let me know which element it is?
Your site is in maintenance mode. I can not see any content.
Cheezballz
Here you go.
You have a static image set as a background image, it overrides the dynamic bg image:
https://app.screencast.com/rTgbbe03gO69e -
Cheezballz
I see. How would I make a ‘default’ bg image for pages that don’t have a Featured Image set?
Try this, replace
100with the actual fallback image ID.function add_fallback_featured_image($value, $post_id, $meta_key, $single) { // Check if we're retrieving the post thumbnail if ($meta_key === '_thumbnail_id' && !$value) { // Set your fallback featured image ID return '100'; // Return fallback ID if no thumbnail is set } // Return the original value if it's already set return $value; } // Hook into get_post_metadata for the _thumbnail_id meta key add_filter('get_post_metadata', 'add_fallback_featured_image', 10, 4); -
Cheezballz
Thanks Ying. Will that create a fallback for place there’s an image? How would I make it specific to an element?
This code create a fallback featured image for all posts and pages.
so you only want it to apply to pages? If so, you can add a
is_page()condition to the code.function add_fallback_featured_image($value, $post_id, $meta_key, $single) { // Check if we're retrieving the post thumbnail if ($meta_key === '_thumbnail_id' && !$value && is_page()) { // Set your fallback featured image ID return '100'; // Return fallback ID if no thumbnail is set } // Return the original value if it's already set return $value; } // Hook into get_post_metadata for the _thumbnail_id meta key add_filter('get_post_metadata', 'add_fallback_featured_image', 10, 4); -
Cheezballz
Got it, thank you!
