How to add heading text and button to Image Gallery carousel
  • hello, how are you
    this is Image Gallery carousel https://prnt.sc/pAxaqiosjoML
    i want to add heading tex and button for each Image carousel item inside Image Gallery carousel layouts
    just like this one https://prnt.sc/wPmxji6JaE30, others keep same
    thanks
    From left panel, select the image and from the three dots next to it, select Add after.. Click the + icon next to the block and add a Headline block. Write your title and adjust typography settings from the right. With the same method as before, add a button block (the blue icon) and adjust settings accordingly.
