how to add left /right spacing for dynamic contentt?
  • Setting up a post template element and using Dynamic Content to place the post inside the template. That is working, however there seems to be no block settings to add spacing on the left or right side of the content. This is bigger problem on mobile, since the content is butted up right agaisnt the left side of the screen.
    Is there a way to add this spacing?
    The link shared requires credentials. We can’t view it.
    If you want to add spacing, you can place all the content of your Content Template inside a Container Block.
  • Thanks – that works.
  • You’re welcome!
