How to add line breaks on terms pages
    I actively use my terms pages.
    I’m having an issue where there are no line breaks in the content, and the HTML sometimes gets completely ignored.
    I’ve been trying to resolve this for a few days but I can’t figure it out.
    I’ve disabled caching and optimization for these URLs for you to check.
    Thank you!
    PS: The more I’m working with Generate Press, the more I like it.
    Is the issue only in the term description ?
    If yes, and if you’re using a GP Element, then instead of the Term Description block.
    Try using a GP Dynamic Content block, and setting it to display the Term Description.
    I am using a block, page hero, after header.
    I changed the block from term description block to dynamic content block, but it doesn’t work
  • I now see line breaks.
    But i also <p> tags inside the text.
    How are you adding HTML to the Post Tag Terms Description ?
  • I use WP All Import.
  • Looks like updating all the descriptions and resubmitting works David. Thank you.
  • Glad to be of help!
