How to add missing Google Fonts to my Font Library
    How can I add missing Google Fonts to my Font Library?
    I tried adding the Google Sans font using the Font Library in the Install Google Fonts tab, but it wasn’t available, even though it’s listed in Google Fonts.
    Many others are missing, such as Lilex and BBH Bogle. It seems that new fonts aren’t available for installation through that tool.
    I appreciate your help.
    In situations like this one, try downloading the font, then drag the downloaded .ttf files into the Upload Custom Fonts area, that should do it!
  • I understand.
    My question is whether the GeneratePress Font Library converts the font to WOFF2 from TTF if I upload it manually, since WOFF2 is the most efficient for the web.
  • That’s a good point. They don’t seem to be converted.
    In this case, you could use this online tool to download WOFF2 versions of your font variants. For example, for Google Sans, you would search the font at the top left and select the variants you want:
    https://i.ibb.co/bg85JJQm/chrome-y-Sty-JFhrc4.png
    Then further down, click the Download button to download a zip file with the WOFF2 files you can upload.
    https://i.ibb.co/xqTmqjfg/wy-OYotw-EDc.png
  • Ok, thanks.
  • Ok, no problem!
