heathery725
How do I add a shadow or border on my featured image here? https://staging.learnplanting.com/soil-care/fertilizer/oak-trees/
It Is a dynamic image within the container…
Hi Heathery,
I’m not seeing the Featured image. Did you remove it? If so, can you add it back?
heathery725
No It should still be there – take a look here: https://staging.learnplanting.com/soil-care/fertilizer/oak-trees/
I see. So one way is to replace that WP Image Block with a GB Image Block and use GenerateBlocks Pro Effects feature. Reference: https://docs.generateblocks.com/article/effects-overview/#box-shadow
The other way is through custom CSS. We can point you in the direction you need to go with here. For instance, try this CSS:
.page-id-14815 img.dynamic-featured-image.wp-post-image { box-shadow: 3px 3px 3px #000000; }
heathery725
I think I’d like to keep the image I have now and insert the CSS – can you point me in the direction of where specifically I insert that CSS? I tried it in the block for the container in the “Additional CSS Class(es)” and that didn’t do anything ha
It should work there.
Can you double-check if there are any syntax errors on your Additional CSS?
There are various CSS syntax error checkers online such as this one: http://csslint.net/
heathery725
I copied your code exactly and inserted it in here:
IS there any way I’m putting it in the wrong spot?
It’s not that it’s in the wrong spot. There could be a syntax error somewhere in your previous codes. This is what I’m suggesting for you to check.
Try adding the code I provided at the very top.
heathery725
there’s nothing in that box besides the code I copied exactly – would you mind logging in and taking a look?
Oh. I see where you placed it. Sorry, I misunderstood. Remove where you added it.
Add it to Appearance > Customize > Additional CSS in your Admin dashboard.
heathery725
Thank you so much I see when I added it a black shade came up. Here was the code I had before I believe to shadow my featured image – I tried to add this to your code b/c I like the specs of it…but it didn’t work. Could you help me adjust the code? Last thing and we can close this out! Thank you!!
.shadow1 {box-shadow: 0 4px 8px 0 rgba(0, 0, 0, 0.2), 0 6px 20px 0 rgba(0, 0, 0, 0.19) !important}
Try this:
.page-id-14815 img.dynamic-featured-image.wp-post-image { box-shadow: 0 4px 8px 0 rgba(0, 0, 0, 0.2), 0 6px 20px 0 rgba(0, 0, 0, 0.19) !important }
heathery725
Amazing – it worked!!! THANK YOU so much
You’re welcome, Heathery!
