How to add the width of the column
  • hi
    pls check the screenshot https://prnt.sc/xYE2IU3yyixb
    now i have 5 content container in one row, but the width of each column is small,
    i want to add the width of each column, please kindly make the video guide for this adjustment,
    the example of the width i expect is like this https://prnt.sc/2nxRsVawjeCN
    thanks
    You need to drag the Grid gb-element-30d54c1e out from its current parent container gb-element-51eba02a, so gb-element-51eba02a‘s width can no longer restrict gb-element-30d54c1e‘s width.
    Then you can increase the max-width set for Grid gb-element-30d54c1e.
  • https://prnt.sc/73CNOLpfaxUt
    please check this screenshot
    It is gb-element-6481c8b6 inside the parent container gb-element-51eba02a, not gb-element-30d54c1e.
    Im right?
    I checked all, dont find gb-element-30d54c1e
    Thanks , please double check it
  • Please ignore the above information and i can not edit or delete it.
    pls check the below informaiton
    How to increase the max-width set for Grid gb-element-30d54c1e?
  • How to increase the max-width set for Grid gb-element-30d54c1e?
    Turn off the Use Global Max Width option, then set the Max Width to a value greater than 1200px, as the current global max width is set to 1200px.
  • thanks
    confirm one thing with you, pls check https://prnt.sc/c5N88tdR3gH3
    the grey default value means Global Max Width Value?
  • Also,
    Yes now I have changed this value from 1200px to 1500 px,
    I want to know
    What is the final maximum value for this value greater than 1200 ?
  • What is the final maximum value for this value greater than 1200 ?
    There is no maximum value. You can set it to any value you like.
    The actual width displayed will still be limited by the visitor’s screen size. For example, if you set the Max Width to 2000px, but the visitor’s viewport is only 1700px wide, the content will only be displayed up to 1700px. The Max Width simply defines the upper limit—it doesn’t force the content to exceed the available screen width.
  • Thanks for clarifying everything and it is clear.
  • No problem!
