How to adjust the image
  • https://prnt.sc/69Vdc6G29qXh
    hi , pls check this screenshot
    It is one image on the right,
    I need to make the top and bottom edges of the image match the top and bottom edges of the background color. How can I adjust it?
    please help to fix that, thanks
    1. Set image to Display as Block.
    Display block
    2. Set its container to have margin-top: -0.5rem, margin-bottom: -0.5rem, margin-right: -10px.
    Container margins
  • https://prnt.sc/Ioby5oK-63AI
    hi George
    Thanks for your details.
    1. Yes, done with your steps, but still there is gap between the images and backgroud container on the top and bottom,?
    2. one more question, pls check https://prnt.sc/77vkaJyt4XtN
    when and how to choose the display style inside the Layout ?
    What is the basis for the judgment?
    for example ,just now from default to block?
    thanks
    1. Remove the margin values that I gave you earlier. For the gb-element-c3e94a1a container, set padding values to 0. For the text container which is the gb-element-5c62e3c9 one, set padding-top and padding-bottom to 0.5rem. Set padding-left and padding-right values to 10px;
    2. Images are inline elements by default, so they sit on the text baseline — and that gap you’re seeing when Display is set as Default is the space reserved for descenders (the tails on letters like g, y, p).
    When you set display: block, the image is no longer treated as an inline/text element, so it doesn’t need that descender space anymore. When you set display: block, the image is no longer treated as an inline/text element, so it doesn’t need that descender space anymore.
    CSS The display Property
  • https://prnt.sc/0CrKq1ga5Ibe
    Hi, George
    I think i have followed your steps, but still there is gap on the top and bottom,
    sorry again, pls help to fix that, thanks
    i have attached temporaty access link to check it for you
    thanks
    Hi, George
    thanks
    Select the gb-element-620b289c Container block and set its Height to 100%.
    Then select the Image block inside it, set Object Fit to Fill, and set the Height to 100%.
    thanks
    https://prnt.sc/cQa-Ys0WxJm9
    where did i find the second Height to 100%?
  • It’s under the Sizing settings.
  • hi
    yes, perfect
    i love you
    good day for you
  • Glad to hear that!
