Anonymous
hi
how are youpls check https://prnt.sc/KVZ-f-48_kza
i have added the background image to carousel item
at the same time, added the overlay color to container with text,
i mean, i want to added overlay color to background image, but all text dont have overlay color and keep the original white color for the all heading text and button text, which is the same with the text on the first and second one
now how to fix that to achieve that,
pls help to fix thant
thanks
Not sure I understand your meaning, it looks like it already does what you wanted.
Let me know if I miss anything. Feel free to explain it in Chinese if it’s easier.
Anonymous
hi Ying, thanks for your reply
hi @ George
would u like to help me explain my questions?
When you add an overlay color to a container, it shouldn’t affect the text. From what I can see, you’ve already applied the overlay color to the container and it’s behaving correctly.
Is there another area where you’re trying to apply this and it’s not behaving the same way?
Anonymous
https://prnt.sc/0Z7izOL4Nvhl
pls check this screenshoti just only want to add overlay color to this background image, don’t want the heading text and button be overlayed in the red box
Do you mean to create something like this?
Anonymous
It is not what I want above.
i think it is easy to understand that.
pls follow me,
1. https://www.iihuan.online/wp-content/uploads/2026/01/1920×600-产品缩小一点点点点点.jpg
check this photo, This is a picture with a white background.2. https://prnt.sc/Erwd5Eh3tCp3
now two heading tex and button are white also,3. I have added the above background image to carousel item container, then i will not see the heading text.
4. i will have to add another overlay color to this carousel item container like this https://prnt.sc/_WdL9sJdCX2j, then user can see the heading texts.
now my question is :
I just want this overlay color to be applied to the background image, and not to the two heading text and button.How to change setting?
Okay, so you want the overlay color to be darker like on the first and second slides, right?
If so, check out this screencast: https://cln.sh/mrs2Q00Y3h7bF1qdsgVl
