Anonymous
hi
how are youI want to move the entire container2 down to the bottom edge of container 1. How should I modify the spacing values or make other adjustments? Please provide guidance. Thank you.
i put url in my message
Could you let us know which one is Container 1 and which one is Container 2 in your layout?
I just want to make sure we’re looking at the correct containers, as it’s difficult to tell which is which from the screenshot you provided.
Anonymous
Hi Alvind
please login the admin with attached information,
Anonymous
you wil find this container 1 and container 2 from this link https://prnt.sc/QWSHefbULV6O
Anonymous
hi Alvind
Did you see the attached login information?
Yes, thanks for the clarification.
However, the login does not seem to be working. Could you please recheck the credentials?
Anonymous
i have updated new login credentials and please use the new one
George
Did you try dragging Section 2 to the bottom of Section 1 in the block editor? Just click Section 2 and drag it to the left. It will be positioned below Section 1.
Anonymous
Hi George,
Thanks for your response.I’m sorry, I cannot understand what you said.
Would you like to show me a screenshot or video of the steps you mentioned above?
You can simply drag Container 2 out like this: https://cln.sh/Kt8hzL1c3K71xcB472rL
That should also resolve the spacing issue, as the layout already has the appropriate spacing configured.
Anonymous
no, it is not what i want
psl check this screenshot https://prnt.sc/-WWxHTWgubLA
i mean, I would like section 2 to move from position 1 to position 2.
so, how to adjust the spacing, thanks, pls show the video guide, thanks
Try this:
Select the Section 01 block, set this settings:
Position: Relative Min Height: 760pxThen select the Section 02, set:
Position : Absolute Under Inset settings, set: Right: 0 Left: 0 Bottom: 0
