How to attach “Article Class” to all “Post Template” blocks globally
  • Hello. How can I attach/assign the Article Class to each Post Template block that’s currently being used globally? Obviously, this is a breeze for content template elements for posts and archives, but for our pages, it’s a bit of a time-eater.
    Any ideas? Thanks.
    Unfortunately, there’s no built-in way to automatically assign all Post Template blocks in an <article> tag site-wide. If you’re referring to Query Loop blocks you’ve manually added to various pages, you’ll need to edit each instance and set the Post Template block’s HTML tag to article manually.
  • Thanks Alvind. Appreciate the response.
  • You’re welcome
