How to best implement a syntax highlighting block
  • Hello there,
    I’d like to include a mock “terminal” on a website, and inside that I’d like to have some code with syntax highlighting. I have a good idea on how to create the terminal with GenerateBlocks, but I don’t know how to do the syntax highlighting part. Should I just use a code block inside my container and a syntax highlighting plugin? Are you aware of a plugin that would be able to work on a GB headline block (targeted through its css class maybe)?
    Kind regards,
    Gunnar
  • Hello there,
    Yes, using a plugin may be better for this.
    I found this plugin which may help: https://wordpress.org/plugins/code-syntax-block/
    It seems to be an extension for the WP Code Block to include syntax highlighting.
    Hope this helps!
