How to build this hero sectio?
  • Hi team,
    I need to create a hero section like this one.
    What would be the best way to go about it?
    I wonder if I need to provide the background image in a very large size so that it fills the full format even on huge screens? Or would it be better to build the section with a max width? Then there would be a white border on the right and left when the user uses a wide screen?
    What is the usual procedure?
    Thanks for help!
    It totally depends on your design, just let us know if you run into any technical issues during the build.
  • It totally depends on your design
    Yes, sure.
    But I think I didn’t express myself correctly. My question referred to the background image.
    What I mean is: if I use the layout 100vh/100vw, what size does the background image have to be so that it is also displayed well on very large screens?
    Do I have to take 4K, 5K or 8K screens into account?
    Do I have to provide the image with a width of 4000px or higher?
    How is this normally handled?
    Thank you!
    Typically, you should use an image that matches the highest resolution you intend to support.
    For example, to support 4K displays, the background image should be at least 3840×2160 pixels to maintain image quality.
  • Yes, I was afraid of that.
    I had hoped that there would be a decision-making aid that you could follow.
  • Unfortunately, we can not make the decision for you! And there isn’t a right or wrong choice, you need to find the balance between the performance and the resolution.
  • Thank you Ying 😊
  • You are welcome   🙂
