fredericco
Hi, support team.
im using 2 buttons from my post meta’s in my posts.
There is always a button, but the other button is not in some articles. How can I center the button when there is only one button?
how are the buttons being added ? are they using dynamic data and if os what type
fredericco
Hi David, im adding buttons dynamic data: https://prnt.sc/aL7XRkAhJLoa
OK. so instead of using a Grid Block to lay out the buttons.
Use a Buttons Container see here:https://docs.generateblocks.com/article/button-overview/
Then in the Buttons Container > Layout , you can
1. set the Column Gap to add space between them.
2. set the Justififction to Center.Then select the Button blocks and in their Layout -> Flex Child set the Grow to
1
The buttins will then share equal space.Now if the dynamic data post meta doesn’t exist the button wont be printed and therefore take up no space, and the remaining buttons will fill that space.
fredericco
Thank you David! 🙂
You’re welcome
