how to change search results page view
  • Greetings.
    Please see the difference between search results page of the sample site and our site below.
    We like how the sample site highlights the searched keyword in search results. This helps the user more.
    Please guide how to fix our site’s search results page to match the sample site.
    Thank you.
    Try adding this snippet:
    function highlight_search_term( $text ) {
        if ( is_search() && in_the_loop() && is_main_query() ) {
            $search_term = get_search_query();
            if ( ! empty( $search_term ) ) {
                $text = preg_replace(
                    '/(' . preg_quote( $search_term, '/' ) . ')/i',
                    '<strong class="search-highlight">$1</strong>',
                    $text
        return $text;
    add_filter( 'the_excerpt', 'highlight_search_term' );
    add_filter( 'the_title', 'highlight_search_term' );
  • Hi, thanks but the snippet doesn’t seem to work.
    Please advise what I need to change.
  • It would work for the default search result template, but it seems you are using a loop template for the search result page.
    However, your search result template only contians a title, no content or excerpt, is that intended?
    If so, I don’t see a point in highlighting the search term, as no title includes the search term in the example you gave us.
    [screenshot removed]
  • Ying,
    No, that is not intended.
    The search result template that came with the theme only contained a title, author name and I believe date. I removed the name and date but there was no content or excerpt to begin with.
    What must I do to display excerpt and highlighted searched key term?
    Thanks.
  • Can you add a text block below the title headline block?
    And set its dynamic tag to excerpt?
  • That worked, thanks.
    However, it still doesn’t highlight the searched keyword.
    Do I need to adjust/remove Alvind’s snippet above?
  • Yes.
    1. Add CSS class highlight-search-term to the title headline block and the excerpt text block.
    Adding CSS class(es): https://wordpress.com/support/wordpress-editor/adding-additional-css-classes-to-blocks/
    2. Add this PHP code:
    add_filter( 'render_block', function( $block_content, $block ) {
        if (
            is_admin() ||
            ! is_search() ||
            ! is_main_query() ||
            empty( $block['attrs']['className'] ) ||
            strpos( $block['attrs']['className'], 'highlight-search-term' ) === false
            return $block_content;
        if ( ! $search_term ) {
        return preg_replace(
            '/(' . preg_quote( $search_term, '/' ) . ')/iu',
            $block_content
    }, 10, 2 );
  • Hi, thanks. Worked for post excerpt but not for post title.
  • It’s working.
    However, the title’s font-weight is set to 700, and the highlighted text is also set to 700, so it can not be seen.
    The font-weight for the title is from global style .gbp-card__title.
    However, I’m not sure if the font family you are using actually has the 700 variant.
    Can you check?
  • Ok. But please note the search result page’s title in the looper is actually getting messed up with html tag showing there and the link not working.
  • I see, can you try updating the code to this?
        if (
            is_admin() ||
            ! is_search() ||
        $search_term = trim( get_search_query() );
        libxml_use_internal_errors( true );
        $dom = new DOMDocument();
        $dom->loadHTML( '<?xml encoding="utf-8" ?>' . $block_content, LIBXML_HTML_NOIMPLIED | LIBXML_HTML_NODEFDTD );
        $xpath = new DOMXPath( $dom );
        foreach ( $xpath->query( '//text()' ) as $text_node ) {
            if ( stripos( $text_node->nodeValue, $search_term ) === false ) {
                continue;
            $new_html = preg_replace(
            $fragment = $dom->createDocumentFragment();
            $fragment->appendXML( $new_html );
            $text_node->parentNode->replaceChild( $fragment, $text_node );
        return $dom->saveHTML();
    }, 10, 2 );
  • That worked, thank you very much Ying.
    If possible, please remove the screenshot here: https://generate.support/topic/how-to-change-search-results-page-view/#post-190150
  • Yes, I’ve removed it 🙂
    Glad it works!
