How to change the background
  • hi
    https://prnt.sc/WSM1k9YNGpb7
    pls check the above screenshot.
    1, the default background is black, where can i found this black color in setting panel?
    2, how to change background color in setting panel?
    3. if needing to add background image as background color, where to add the background image?
    i tried , but not useful
    pls show helpful file or let me know the steps, thanks
    one more thing, where can check the official helpful files about the lastest funcitons
    Select the Container inside the first Carousel Item. On the right, in the Backgrounds section, you can change the background color.
    Change slider background color
    To add a background image, with the container selected, click the + icon next to the BACKGROUNDS and select the image you want.
    Here is related documentation.
  • hi
    yes
    https://prnt.sc/nyQdI-0eB85B
    check the url
    i added the backgournd image for the first casourel itme, but i can not see background image in the front end,
    pls help to check it, thanks
    You need to remove the black background color, as it’s covering the background image. Refer to George’s screenshot above for the exact Background Color setting location.
  • hi, thanks for your quick reply
    pls check https://prnt.sc/m9dFJ0kIsxPK
    when adding background color or background image, i need to add it to container 1 or container 2??
    if choosing any one, what is the difference between them?
    pls clarify them, thanks
  • If I choose the background image, what is the size of the default background image to get the best display result?
  • hello
    for this hero carousel https://prnt.sc/0JEptUaQ0D3I
    For arrow control or dot control, Modify the settings and enable it to play automatically?
  • hello
    for this page
    https://prnt.sc/PkAKvpmYVBu3 – the bakcgournd image and dot control of this carousel item is normal
    https://prnt.sc/NdjUjkdb_OlL – other two caoursel items are not normal , where is the problem, ?
    plese help to fix them, thanks
  • hello how are you
    pls check this screenshot https://prnt.sc/LCGkH4RTZwHx
    I want the text within the red box to move only to the left, without covering the product image on the right. How can this be done? Is it feasible?
    please help me to fix that, thanks
  • when adding background color or background image, i need to add it to container 1 or container 2??
    The background should be added to the root container, which in your case is the Carousel Item block (Container 1).
    The image should match the aspect ratio of the container. The exact image size doesn’t matter—as long as you use a high-resolution, optimized image, it will display correctly.
    I’m not entirely sure what you’re referring to here. Could you clarify what behavior you’re trying to achieve?
    for this page
    Select the Carousel Items block, then remove the Height value under Sizing settings. That should fix the inconsistency.
    Yes. Select the inner container inside the Carousel Item block, then set Align Items to Align Start under Layout > Alignments.
  • for this page
    https://prnt.sc/SdcmJZk19Clj – here container block don’t have height value under sizing setting
    https://prnt.sc/bFzQMTfgFDyF – here three are all mini 500,
    no any extra height value,
    so please help to fix again, thanks
  • I want the text within the red box to move only to the left, without covering the product image on the right. How can this be done? Is it feasible?
    pls check below screenshot
    https://prnt.sc/O-7FAfOUTZBI
    set Align Items to Align Start under Layout > Alignments for inner container, but the whole text keep the same postion,
    pls help to fix that, thanks
  • https://prnt.sc/OgOiJwszy04l
    https://prnt.sc/L9Zf-dm200zw
    i have added new background images for the second hero silder and the thried hero slider in wordpress admin, then saved
    but i can not see them in the front end
    where is my problem, pls help to fix, thanks
  • https://prnt.sc/_JSRlVDlYu18
    please check it
    i want Autoplay for this arrow casourel control,
    How to set them?
  • Select the Carousel block and from the right panel, activate Start Autoplay Automatically toggle.
    Carousel autoplay
  • hello
    Could you show me the route/steps I activate Autoplay Automatically?
    i try to find the toggle in the right panel, really can not.
    also, i have more other questions beside this one, please check and give helps.
    it is really urgent
    now the generatepresblocks have big update
Viewing 16 posts - 1 through 16 (of 48 total)
