How to change the background
  • Select the Carousel block and from the right panel, activate Start Autoplay Automatically toggle.
    Then Save your page. You will find the toggle on the right panel if you scroll down a bit.
    As far as your other questions: Let’s take them one by one, otherwise, we are all going to be confused, lol. Let’s solve this one, then, when it’s done, let us know what is next. Sounds good?
  • hi, yes, this one is done and sovled, now it is autoplay.
    please help me to solve the next one question, it is urgent,
    im here waiting for you here, thanks
  • Ok, regarding the background images not being visible even though you have uploaded them. That seems strange.
    Please go to GenerateBlocks->Settings. If the CSS PRINT METHOD is set to External File, click the Regenerate CSS Files button. Check the page again.
    If that doesn’t work could you please provide site credentials so we could have a look for you? Please use the private section of your reply to post them. You can also install the Temporary Login Without Password plugin and send us a login link without using a password. Again, please, use the private area of your reply to send those details.
  • hi George
    pls check the login link in the private message
    thanks
    I do see the background image in the editor, this is what I see:
    https://app.screencast.com/ROBvtZ21mUjFG
  • Hi Ying
    pls check my question carefully carefully carefuly carefully,
    not first one background image
    i mean the second one and third one,
    thansk for your paitent
  • Hi Ying
    Please check and read the above topic for my this question.
    why George asked the login link?
    I just checked the page and the particular carousel, each carousel item has the same background image!
    Here is the second carousel item, it has the same background image as the first.
    Carousel background image
  • hi George
    on my end,
    the second background image is https://www.iihuan.online/wp-content/uploads/2026/01/999.jpg https://prnt.sc/Q1KDtQfow7kY
    the third background image is https://www.iihuan.online/wp-content/uploads/2026/01/66666.jpg https://prnt.sc/lhJ-_ABtliym
    pls check them
    why the different we have seen the different result
  • hi George
    psl check the site hero slider after menu , dont check the slider inside the page
    https://prnt.sc/1TkIzNLao19w
  • Ok, can I take over from you please? You seem to be editing it right now.
  • hi George
    backgrond image is OK now on my end
    Please help me to fix next issues,thanks
  • https://prnt.sc/BWfVoKgcLUGe
    the whole heading text including button move to the left, dont cover the produdts
    https://prnt.sc/yu_0OT3_Fyfz
    the whole heading ext inclding button move to the top, dont cover the produts
    pls show the steps ,thanks
  • Ok, I fixed it. The issue was that the hero carousel was sharing the same ID with the one further down. Since they were appearing on the same page, it was causing issues. I duplicated the hero block to generate a new block ID, it should be good from now on.
  • Ok, for centering the text. The flex container needed to be centered. ALIGN ITEMS and JUSTIFY CONTENT needed to be set to Center.
    Centered flex cotnainer
    Second carousel item: The container below the Carousel item has some padding:
    Container padding
    Click the link icon next to the PADDING title and set 0 for the Top value.
    0 padding value for container
  • HI George
    where to change this?
    ALIGN ITEMS and JUSTIFY CONTENT needed to be set to Center. — they are OK
    Now all whole heading texts are still centered.
Viewing 16 posts - 17 through 32 (of 48 total)
