Anonymous
hello
pls check https://prnt.sc/3t-pUssbTWPI
Can I change the style of carousel control for this image gallery carousel?the default one is not good
if i can change it, pls guide me or show me the guide file from you\
thanks -
You can try this CSS, and adjust the values according to your design.
:where(.gb-carousel-pagination)[data-pagination-type=progressbar] .gb-carousel-pagination-progressbar-fill { background-color: red; } .gb-carousel-pagination.swiper-pagination-progressbar.swiper-pagination-horizontal { background-color: rgba(0, 0, 0, 0.1); height: 10px; max-width: 100%; border-radius: 2px; } -
Anonymous
hi
You misunderstand my meaning.I want to have the arrows centered vertically. How to change it? pls help, thankks
First, select the Carousel block and set its Position to Relative.
Next, select the container holding the arrows and set its Position to Absolute, Inset > Top to 30%, Width to 100%, and Z-Index to 1.
Anonymous
hi,yes, thanks
where can i set Width to 100%, in the right panel? i dont find it.
Anonymous
once arrow control is done, can i delete this line contron at the bottom? if deleting it, it will not affect the whole casourle block container?
You’ll find it under the Sizing settings in the block sidebar.
Yes, you can remove it. That line is just the pagination indicator and removing it won’t affect the carousel’s functionality.
