How to create a dynamic download button with GB & Metabox?
  • Hi
    using Metabox.io I have created a custom field “mediakit” of the type “file_advanced” for the CPT “Talents”.
    I have also created a Content Template for the CPT “Talents”, where I need a button for downloading the file.
    Under the Dynamic Data section of the button blocks panel I have set
    Data Source = Current Post
    Link Source = Post meta
    Post Meta Field = mediakit
    Link Type = Default
    but on the frontend the file won’t be downloaded on posts, where I had uploaded a pdf using this field.
    What irritates me is, that under “”Link Type” I don’t have a “Download” option to chose from, only Default, Email & Telephone.
    What else I need to configure in order to turn the button into a download button for this “mediakit” file?
    Thank you in advance and kind regards,
    Sascha
    in GB PRo, you can add attributes in the Advanced Panel of the block settings.
    Select your Button
    In Advanced > Add Attribute and just type: download
  • It does not work.
    I have added “download” to the data-attribute field (not the value field). But instead of the PDF it will download a html-screenshot of the post! I have already tried to change the Button Type from “Link” to “Button”, but then nothing happens.
    Can you please help me dig further? Will provide login-details and link to Element & Post in private note field.
  • The login your provided won’t allow me to view ( or edit ) posts.
  • Oops, pardon, gave wrong role to the temporary-admin …
    Now it has full admin privileges 🙂
    I also added the link to the custom fields to priv notes…
    Warm regards
    Sascha
  • Hi Sascha,
    The return value of the field seems to be an ID.
    For debugging, could you create a Hook Element hooked before_header and displayed to that Post with this code:
    <?php
    var_dump(get_post_meta( get_the_ID(), 'mediakit' ));
    This would output the value of the field so we can debug.
