How to create Related Posts AFTER post?
    I want to create automatic Related posts after every post as per the category. How to do that?
    Thanks.
    You will need a plugin for this.
    If you have GB Pro, you should be able to create simple related posts as well, here’s the doc for GB’s query loop block:
    https://docs.generateblocks.com/article/use-query-loop-block-to-create-related-posts/
  • I am a PRO user. I would like to have related posts appear at the bottom of every post. Could I request more detailed instructions?
    update)
    Sorry, GB Pro?, I am GP Pro user…
    you would need to use a Related Posts plugin, as the to do this in GenerateBlocks requires the GenerateBlocks Pro plugin
  • Thank you David,
    I obtained the following code through web surfing, but there is a bug that retrieves posts from all categories instead of just the same category. Is it possible to fix this?
    <div class="related-posts">
    	<h4><span><?php $categories = get_the_category();
    echo esc_html( $categories[0]->name ); ?></span> Related Posts/h4>
    <?php
    $post_id = get_the_ID();
        $cat_ids = array();
        $categories = get_the_category( $post_id );
        if(!empty($categories) && is_wp_error($categories)):
            foreach ($categories as $category):
                array_push($cat_ids, $category->term_id);
            endforeach;
        endif;
        $current_post_type = get_post_type($post_id);
        $query_args = array(
            'category__in' => wp_get_post_categories($post->ID),
            'post_type'      => $current_post_type,
            'post__not_in' => array(get_the_ID()),
            'posts_per_page'  => '5',
            'orderby' => 'rand'
        $related_cats_post = new WP_Query( $query_args );
        if($related_cats_post->have_posts()):
             while($related_cats_post->have_posts()): $related_cats_post->the_post(); ?>
                <ul>
                    <li>
                        <a href="<?php the_permalink(); ?>">
                            <?php the_title(); ?>
                        </a>
                    </li>
                </ul>
            <?php endwhile;
            // Restore original Post Data
            wp_reset_postdata();
         endif; ?>
    </div>
    Sorry, but that would be out of our scope. Quickly glancing at the code, try replacing $post->ID with $post_id.
    Otherwise, if this doesn’t work, our recommendation would be to use GB Pro for this.
