I would like to disable the title for all posts that use a header element. I could do this individually or using a layout element. But I would prefer a more automatic solution. I could use CSS and the :has pseudo-class, but this feels a bit hacky. Do you have an idea how to achieve that programmatically?
Thank you, Mike
You can try this method:
1. Create a new Layout Element to disable the post title. Do not set any Display Rules, and note its ID.
2. Add this snippet:function my_layout_depends_on_header( $display, $post_id ) { // The Layout Element we want to conditionally display. $layout_element_id = 2; // The Header Element that must be present for the Layout Element to display. $header_element_id = 1; // Only modify behavior for our Layout Element. if ( $post_id === $layout_element_id ) { // Get the Header element's display conditions. $header_display_conditions = get_post_meta( $header_element_id, '_generate_element_display_conditions', true ) ?: array(); $header_exclude_conditions = get_post_meta( $header_element_id, '_generate_element_exclude_conditions', true ) ?: array(); $header_user_conditions = get_post_meta( $header_element_id, '_generate_element_user_conditions', true ) ?: array(); // Check if the Header element would display on the current page. $header_displays = GeneratePress_Conditions::show_data( $header_display_conditions, $header_exclude_conditions, $header_user_conditions ); // Only display our Layout element if the Header element would display. return $header_displays; } // Return original value for other elements. return $display; } add_filter( 'generate_element_display', 'my_layout_depends_on_header', 10, 2 );Replace the following IDs accordingly:
$layout_element_idβ The ID of the Layout Element you just created.$header_element_idβ The ID of the Header Element applied to the posts or pages where you want to hide the title.Let me know if that works!
Sorry for not replying earlier. I didn’t get a notification of your post.
Your solution totally works, but it has two drawbacks: It works only for one header element that has to be replaced. So, I would need an array of IDs to be replaced.
In my specific case it could be even more straighforward. The post title should be removed for ALL posts that use a header element.
I should have added more background information in the original post. The header elements always contain an H1 heading and a background image. Since this is the default layout on pretty much all of my pages that use a header element, a function would be a much better solution than using the layout setting for every page or a specific page template. In fact, this is such a standard scenario that a checkbox in the header settings (to disable the title) would be a great feature. A full-width header image with no text is a rare exception. Since this is the first important text on the page, it makes perfect sense to use an H1 heading.
Thank you, Mike
Hi Mike,
Why not use a block element – page hero instead of the header element?
The block element – page hero has a built-in function to disable the default title.
Let me know π
Hi Ying,
I don’t use the block editor (and I hope, I will never have to). π I fully understand that you are more focused on developing block elements. On the other hand, I think that a code snippet would be very handy for many users that love GP but not the block editor. I have the feeling that I’m not the only one. π
Thank you, Mike
If you have multiple Header elements, you can try this snippet instead:
function my_layout_depends_on_headers($display, $post_id) { // The Layout Element we want to conditionally display $layout_element_id = 2; // The Header Elements - layout will display if ANY of these display $header_element_ids = array(1, 3, 5); // Add all your header IDs here // Only modify behavior for our Layout Element if ($post_id === $layout_element_id) { $any_header_displays = false; // Check each header element foreach ($header_element_ids as $header_element_id) { // Get the Header element's display conditions $header_display_conditions = get_post_meta($header_element_id, '_generate_element_display_conditions', true) ?: array(); $header_exclude_conditions = get_post_meta($header_element_id, '_generate_element_exclude_conditions', true) ?: array(); $header_user_conditions = get_post_meta($header_element_id, '_generate_element_user_conditions', true) ?: array(); // Check if this Header element would display on the current page $header_displays = GeneratePress_Conditions::show_data($header_display_conditions, $header_exclude_conditions, $header_user_conditions); // If any header displays, set our flag to true if ($header_displays) { $any_header_displays = true; break; // We found one header that displays, no need to check others } } // Display our Layout element if any of the Header elements would display return $any_header_displays; } // Return original value for other elements return $display; } add_filter('generate_element_display', 'my_layout_depends_on_headers', 10, 2); -
Works like a charm. Awesome! Thank you very much!
Mike
Glad to hear that! π
