How to display an icon only if the post in the loop has an excerpt
  • Hi there, so I have the following issue:
    – I have an SVG icon which I have created using the ‘Headline’ GenerateBlock on my website. This icon is part of a ‘query loop’
    – I only want this icon to display if the current post within the query loop has an excerpt field filled in.
    Please can you tell me how this would be possible?
    Thanks,
    Keith
    you could try something like this:
    1. add this PHP Snippet to your site:
    function remove_block_if_no_excerpt( $block_content, $block ) {
        if (
            !is_admin() &&
            ! empty( $block['attrs']['className'] ) &&
            strpos( $block['attrs']['className'], 'has-excerpt' ) !== false
            global $post;
            if ( empty( $post->post_excerpt ) ) {
                $block_content = '';
        return $block_content;
    add_filter( 'render_block', 'remove_block_if_no_excerpt', 10, 2 );
    2. Select the block you want to display IF there is an excerpt, and in block settings Advanced > Additional CSS Classes add: has-excerpt
