How to display featured image after first paragraph
  • I dont know if there is a newer solution for displaying featured image after first paragraph.
    I was using the hook from David here
    It was working at front but I was getting error undefined $post variable and null property error for the $post->ID. in error_log file.
    So, I used global $post; and changed function like following:
    add_filter( 'the_content', 'insert_featured_image', 20 );
    function insert_featured_image( $content ) {
        if ( ! is_single() || is_admin() ) {
            return $content;
        global $post;
        // Safety check in case $post is null or not an object
        if ( ! isset( $post ) || ! is_object( $post ) ) {
            return $content;
        // Check if post actually has a featured image
        if ( ! has_post_thumbnail( $post->ID ) ) {
            return $content;
        $feat_img = get_the_post_thumbnail( $post->ID, 'post-single' );
        return prefix_insert_after_paragraph(
            '<div class="incontent-featured-image">' . $feat_img . '</div>',
            1,
            $content
    function prefix_insert_after_paragraph( $insertion, $paragraph_id, $content ) {
        $closing_p = '</p>';
        $paragraphs = explode( $closing_p, $content );
        foreach ( $paragraphs as $index => $paragraph ) {
            if ( trim( $paragraph ) ) {
                $paragraphs[$index] .= $closing_p;
            if ( $paragraph_id === $index + 1 ) {
                $paragraphs[$index] .= $insertion;
        return implode( '', $paragraphs );
    It works fine and no errors, I want to know if my function is correct and safe. if so, that function should be updated.
    Your code looks solid 🙂
