Im a new user trying to get used to the theme. I am currently editing EXPLORE starter site.
The problem I currently have is with the home page element. I changed the content of the 4 buttons on the home page, but their design changed. Its no longer showing White font with border.
Another problem I have is with the “Thank you to our sponsors” logos. I don’t know how to make my own chosen logos to align like the original. I used the same size of the original logo by downloading one and using the size to create 4 of mine. But when I upload them, they dont appear as the original.Thanks
Can you try disabling all plugins except GB and GP Premium? It seems something is adding a
<p>tag to the GB buttons and causing the style issue.For issue 2, I’m not seeing your logos, can you upload and clear cache so I can see the issue?
https://app.screencast.com/Sq2sWtRdE2zkZLet me know!
For Issue 1, I did as you said, no change
For issue 2, I removed the logos since it wasn’t looking fine at the time. I can add it back if you are around to advice -
I’m not sure about other plugins, I can clearly see the cache plugin is still on. Can you keep all plugins except the 2 plugins I mentioned for us to inspect?
For issue 2, yes, please do so.
I disabled everything including the cache plugin and tested it. It didn’t work. I enabled only the cache to clear cache just to see if that will help. But still didn’t work.
Tomorrow I will upload the 4 logos
Hi Nkem,
I see. So we can investigate why issue 1 is occurring, can you provide admin login credentials through the Private Information field?
I have uploaded the 4 Logos
Also admin access sent via private field -
I jawst observed that the theme uses block editors. I didnt know about that. So I got the Logos fixed, but yet to fix the Top buttons issue 1
Updated
can you edit each of those buttons and give each of them a Link even if temporarily you just add a
#in the link URL field.Then the button styles should reflect on the front end.
All is ok now. Thanks
Glad to hear that!
