have a problem with shapes1. not showing shapes – container with starting text “More about program KICKSTARTin and its values & purposes and ending with the button “reserver your spot” https://nikamak.com/
2. space between shape and picture on mobile version with the container that is after that is mentioned in #1 – should be no space, and in editing mode, I don’t see the space.
thanks for your help in advance
(if you need print screens, please share with me how I can put them here). -
1. Can you select the Container Block, and in block settings Layout, set the Position to Relative
2. fix #1 first and then let me know
Hi!
number 1 done but still no shapes. -
I am not see the position relative on that container.
Its the Container Block that has the HTML Anchor of:values-and-purposes
Can you make sure thats the one you add the Position Relative to
Sorry, I did for the inner one. Now it is done and I see the wave!
Ok, so #2, the Container below that , select that and change its Layout > Display to Flex on Mobile view
done. but it broke it 🙁
Not seeing the change David asked for, can you make sure you’ve set the container with ID
sign-up-for-guides
is set todisplay:flex
andjustify-content:center
on mobile? -
thank you, now it is more clear. Done and working! thanks. Can you suggest me a quick read about “flex” and “relative”?
Hi Ustar,
You can read more about them here: https://docs.generateblocks.com/article/layout-options-overview/#flex
https://docs.generateblocks.com/article/layout-options-overview/#positionAlso see for more learning:
https://developer.mozilla.org/en-US/docs/Web/CSS/CSS_Flexible_Box_Layout/Basic_Concepts_of_Flexbox
https://developer.mozilla.org/en-US/docs/Web/CSS/position -
Thanks a lot!
You’re welcome, Ustar!
