hws991215
-> How do I set up the query loop on the page to make it appear the same as this main site? Please let us know with screenshots or videos. I will give you rights as the owner.
Hi Hws,
Try following the thread here: https://generate.support/topic/i-need-help-recreating-this-layout/#:~:text=I%20see.%20You%20just%20need%20to%20alter
The layout there looks similar to what you’re trying to achieve.
hws991215
Even looking at it, I’m not sure. Can you tell me step by step based on the benchmarking site I told you about? -> Please let us know with a screenshot or video here.
hws991215
Even looking at it, I’m not sure. Can you tell me step by step based on the benchmarking site I told you about? -> Please let us know with a screenshot or video here..
1. Select the top Container Block and set the Spacing > padding to 30px on all sides.
2, You need to adjust your font sizes – see here:
hws991215
I want to set it as a static page. Is this possible?
They you need to:
1. create a static page.
2. build the layout using a Query Loop Block, NOT a GP Element. -
hws991215
Please tell me how to do it step by step with screenshots or videos.
You can start by adding a GB Pattern, there are some that are similar to the layout your require.
For example:https://generateblocks.com/library/?pattern-category=query-loop&pattern-preview=4187
hws991215
->Please tell us step by step with screenshots or videos here.
Here’s a screen recording: https://share.zight.com/KouN8e2n
hws991215
-> Please check this. I want to make this static page exactly like
You can add colors: https://share.zight.com/nOuQ2NrA
https://share.zight.com/geu1K2elFor the Image, you can set the object-fit to Contain: https://share.zight.com/Blu2PBA6
Try to play around with the settings of the Blocks to get the outcome you want.
On the Frontend, the excerpt should show. You can test this out if you publish that page and view the page on the frontend.
hws991215
-> Thank you. Please check this.
For the spacing, you just need to alter the Post Template Block padding: https://share.zight.com/YEuzb1pD
For the Archive link, here’s a video: https://share.zight.com/YEuzb1pD
hws991215
I want to do exactly the same. Can I add a category using the p tag instead of a button? And you sent me two identical links. Please do it again.
