how to make section wider?
    I’m wondering how I can make the following section wider for desktop and tablet modes. The mobile version is fine as it automatically goes to the next row.
    Whenever I try to adjust it for desktop and tablet, it either shrinks or the second table goes to the next row.
    So, my question is, how can I correctly make it wider?
  • Hi there
    that 2 column Grid Block is sitting inside a Container Block.
    Select the Container Block and set the Layout > Display to BLOCK.
    Currently it is set to Dipslay Flex , Column which allows for the grid ( which has not set width ) to collapse to the width of its content.
  • Do I need to change both grid blocks to ‘BLOCK’ ?
    Currently this is your layout structure:
    -Container #1
    --Grid Block
    ---Grid Column #1
    ---Grid Column #2
    You need to set the Layout to Display > Block on the Container #1
  • awesome thanks!
    For desktop it works fine. do I need to change also for tablet and mobile to ‘block’ for best results?
    On Tablet and Mobile, if there is no value set (eg. the Display = Default ) then it will inherit Desktop setting. So theres no need to change it unless its set to a different value
