digitalnomadguy
how to make the 2 containers closer
I would create a section with an inner container that has a max-width.
eg.Container Block #1 ( Section ) ---- Container Block #2 ---- ----- Column Container ---- ----- Column Container
Container Block #2 can have a Sizing > Max Width set and Spacing > Margin Left & Right of
auto
This will fix the width of the content and keep it centered. -
digitalnomadguy
The column block is a WP core block, we don’t have control over it.
You do not need to use the column block at all, you can wrap the text and form in one container.
And set the parent container (Container Block #2) to be
display:flex
digitalnomadguy
how to make the container show the full image?
digitalnomadguy
i think i was able to solve the full image. however the other button height is too big.. i want it slim like the button on the left
because there isn’t enought space! Select the grand parent container and parent container of the button, reduce their left/right paddings.
digitalnomadguy
sorry are you mad?
Lol..no, not at all! why would I? Because I used a
makes you think I’m mad? -
digitalnomadguy
yeah hahahaha okay peace out
Peace 😛
