Anonymous
hi
how are youpls check the screenshot,
How to make last two containers, or total 5 container center on mobile device
pls make video guide , thanks
It’s not possible with Grid.
You will need to select the Grid block(gb-element-6481c8b6), switch to mobile, and change its
displaytoflexinstead ofgrid, setflex-wraptowrap, setjustify-contenttocenter. -
Anonymous
hi
yes, all are certered according to the above guide,but there is new issue and pls check the screenshot https://prnt.sc/b-FBNIUyJ_C-
Content and border lines require an appropriate spacing.
please guide how to adjust it, thanks -
You can select each of the containers and add left/right paddings to them.
Anonymous
yes, right,
but pls check this screenshot https://prnt.sc/Qp9i9KbsspNc, It is Mobile device
For gb-element-6481c8b6, how can I adjust the Max Width to reduce the spacing of the Red Box on the left and right side in the screenshot?
If you view the layout on an actual mobile device, you’ll see that it already spans the full width with the appropriate margins: https://cln.sh/09xS3jJ1Pty6RxsqnqwV
The editor preview doesn’t always match the frontend exactly, so it’s always best to check the live page to see the final result.
If you want to increase the space on the left and right sides of the Grid, simply add values to the Margin Left and Margin Right settings. It will create additional spacing while keeping the layout centered.
Anonymous
Thanks for clarifying them.
I want to reduce the width of the red box area to provide more space for the content in the middle.
So, how to adjust the spacing or margin to reduce the width of the red box area I labeled?
The parent container isn’t limiting the content width, the only spacing added to the left and right of this section is from container gb-element-51eba02a, which has 5px left/right paddings on mobile. You can set that to 0 to gain 10px more space for the child containers.
If you want the child containers’ width to increase, you can increase their left/right paddings. Or set their
flex-growto1, so they will automatically increase their width to try to fill the entire horizontal space.
