How to only show the ‘secondary menu’ (desktop and mobile)
  • I am having inconsistencies with displaying the menus correctly.
    I.e the primary menu has never displayed correctly on mobile and if I deselect the Primary Menu option, it automatically shows all my website page links on the screen
    I therefore think it is best to only display the ‘secondary menu’. How to achieve this?
    Navigate to Appearance > Menus. In the ‘Select menu to edit’ dropdown, choose your Secondary Menu and click Select. Then, under Menu Settings > Display Location, check the Primary Menu option and click Save Menu.
  • I only want to show the ‘Secondary’ menu though, as the Primary menu doesn’t work. Thanks though.
  • Have you tried following the instructions provided by Alvind? If you follow it right, it should do what you were asking for.
