Hi, this is an extension to the “secondary theme menu” we discussed in issue https://generate.support/topic/secondary-theme-mobile-menu/.
I’ve almost got everything the way I want. Taking your advice, when I’m on a page that uses the secondary theme, I swap the menu out using the
wp_nav_menu_args
hook. That allows me to re-use the setup as displayed on my primary theme menu. However…The primary menu includes the search icon, which we don’t want displayed in the secondary theme menu. Is there a way I can programmatically remove the search icon, which I would do from the same chunk of code that swaps the menu out?
I tried removing the hooks as shown in https://docs.generatepress.com/article/navigation-search/, but it had no effect.
Hi Scott,
Can I see the site in question?
And as this question is related to GP Premium, can you also add GP support key to your profile?
Not all pages display the menu, but you can view it at https://dev.acornfinance.dev/contractors-new-design/. Note that the icon has been hidden with CSS right at the moment. And that link displays two menu bars, the top one is the “real” one. Admin login below.
Support key added.
The code I’ve been using to remove the search icon is:
remove_action( 'generate_menu_bar_items', 'generate_do_navigation_search_button' ); remove_action( 'generate_inside_navigation', 'generate_navigation_search' );
I’ve tried executing it from the ‘wp’ hook as well as the ‘init’ hook.
Hi Scott,
If you want to remove it for all pages, try disabling it from Appearance > Customize > Layout > Primary Navigation. Or, are you wanting to remove it for specific pages only?
Specific pages only.
Which specific pages for instance?
The one I listed above: https://dev.acornfinance.dev/contractors-new-design/
Can you try this?:
add_action( 'wp', function() { if ( 'enable' === generate_get_option( 'nav_search' ) && is_page( 240631 ) ) { remove_action( 'generate_menu_bar_items', 'generate_do_navigation_search_button' ); remove_action( 'generate_inside_navigation', 'generate_navigation_search' ); } }, 20 );
That worked, thanks!
You’re welcome, Scott!
