Davepp
Hi There,
I’m working with the scribe starter site trying to recreate the scribe posts grid on the blog archive on a custom post type archive. I’ve duplicated the ‘archive cards’ template and applied this to the custom post type archive but the grid is not applied. Nor can I see where the grid element is applied within the content template. Grid I’m trying to recreate https://mwprop.ogmaworks.com/ cpt archive with copied template here https://mwprop.ogmaworks.com/provider-profiles/
Any help would be great.
Dave
The columns are not activated for CPT, you will need to use PHP code to activate it.
add_filter( 'generate_blog_columns', function( $columns ) { if ( 'provider_profile' === get_post_type() && ! is_singular() ) { return true; } return $columns; } );Adding PHP: https://docs.generatepress.com/article/adding-php/
For more info, please check this guide:
https://docs.generatepress.com/article/using-columns-in-the-blog/#adding-columns-to-your-custom-post-type -
Davepp
Thanks Ying,
Much appreciated. I’m now looking to remove the featured post from the cpt archive, but I’d like to keep it on the posts archive. If I uncheck the customizer option, then it removes from both archives.
Thanks Again
Dave
Try replacing the previous code with this new code:
add_filter( 'option_generate_blog_settings', 'yh_custom_cpt_settings' ); function yh_custom_cpt_settings( $options ) { if ( 'provider_profile' === get_post_type() && ! is_singular()) { $options['column_layout'] = true; $options['featured_column'] = false; } return $options; }Let me know if this helps!
Davepp
Thanks very much, I had a bit of a play with that but with a little AI help I’ve got there I think, all look ok to you?
add_filter( 'generate_blog_columns', function( $columns ) { if ( 'provider_profile' === get_post_type() && ! is_singular() ) { return true; // Enables columns } return $columns; } ); add_filter( 'option_generate_blog_settings', function( $options ) { if ( 'provider_profile' === get_post_type() && ! is_singular() ) { $options['featured_column'] = false; // Disable featured column } return $options; } ); -
Looks good 🙂
