hws991215
As you can see from the screenshots and links, that appears to be the problem. I reduced the size of the picture as much as possible and also reduced the css. but it comes out like this What should I do? Thank you always.
I will also give you the rights of the right holder. -
Try uploading a smaller-sized image. Something like
156 x 124pxcould be good. -
hws991215
All right. But it seems like a capacity problem, is it okay to reduce the image size?
It’s an Image Size problem as per PageSpeed Insights. It should be okay to reduce it.
hws991215
Ok. Thank you.
You’re welcome!
