Anonymous
What I am trying to do is to remove completely posts content from a category. I almost achieved it but I am not able to remove the first words from a post that appear in the category. You can check this category – i want to remove the words “test test test”
Thank you! -
instead of using a GP Block Element – Hook to add content above the archive. Use a GP Block Element Loop Template, this element will replace the default content of the archive .
Anonymous
Thanks, it works that way. But now some other issue appears. I want the first container to be full width. I’ve set it to full width already but through the Block Layout but that doesn’t change anything. What is the way to make full width?
Thank you! -
You can use a separate Layout Element to set the Content Container to Full Width on your Category Archive pages.
https://docs.generatepress.com/article/layout-element-overview/
Anonymous
Did it and it works, yeap. Here is the result – https://betting-websites.net/velobet/.
Thank you! -
Awesome – looks great.
Glad to be of help!
