Johan_NL
The Woocommerce Cart and Minicart are showing a piece of the short description. Is there a way to remove them?
So far I managed to find a CSS code but it’s removing all meta data. As Im using add ons I want to display them but not the short product description.
Thks in advance!
Can I see the issue on your site?
Johan_NL
Try this css:
.wc-block-components-product-metadata__description { display: none; }
Johan_NL
Tried this already but it’s removing all data from the shopping cart. Only the short description i like to have it removed but other things like selected add ons need to be in.
It should only remove the short description, I’ve tested it.
Just to confirm, you are referring to this, right?
https://app.screencast.com/6z6fa9O3hcDUX -
Johan_NL
Sorry, It’s working perfect! You made my day Ying, Thanks!
